I thought about doing something like that and couldn't come up with a decision. If I were to do that, would I lose any loudness?
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
Ull loose a little from fireing through a seat but id take the very little lost output instead of my car rattling like hell. And if the seats fold down and u seal it off it would be much louder
Not at all your going to gain from it.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
u wont loose anything.. ur system will be louder since all air will be going into the cabin!
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Well in my expierence i lose from it. In my grand am but i didnt get to seal it so u may gain it back. But my case it was louder faceing away from the seat unsealed then it was fireing into the cabin. Given this is all unsealed
with right enclosure it will be louder!
seems like i need to start tossing some numbers into the box calculator. Would it help if i added a layer of mdf to the back of the seat? Or would that end up being counter productive?
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
Decided to paint my rims today, they were all scratched and beat to hell. The paint made them look way better on the drivers side, they were ganked pretty deep.
This is about as clean as I could get them with my power washer.
Some paint spots still drying. But this is pretty much how they turned out. Flat Black on all 4.
Also took what paint I had left and painted my box a bit. Definitely wish I had primer when I painted it... All the glue marks showed up a lot.
Also this past week I've been working on setting up shop in my bottom garage
After I put a thin primer on the walls. (you can see my bad graffiti on the wall)
Garage has tunes.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
can u upload a picture of entire car?
I was thinking about plasti-dipping rims in my car..
