Ninja's NASTY Double Hairtrick FROM THE TRUNK!!! MUST SEE
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
12k?? I only seen 2 2500s in there... maybe I missed it..is there 4?? But jacob you think you could post the vid of my boys caprice with the 15s in it?
Edit..just watched the vid.. he must of switched out equipment or something.. my bad
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
Hmmmm I think thors in trouble ... Nice fi ftw
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
It did have the Orion 2500ds in there.
He swapped the amps out a while ago
Sub Amp: 3 DC 9k's
