INFINITY G35 COUPE Build Log, Loud and fast! UPDATES 7-14-13
Ahh that makes sence, i happen to love when you cant see wires at all. Only wires you can see inside my truck is down by the heater box on drivers side where my distro block is. Everything else is pure ninja
alright back to work , removing battery
Seeking secret passage way
Pulled rim, removed fenderwell
found the hole,
OK, the hole in the top middle is from the battery, the grey looking hole to the left in the pic is through the fire wall
On the other side
I like holes, now to make it larger so Sky highs 1/0 can go through
Houston we have penetration!
Up into the battery area
Battery area through the firewall
Into the car we go
Fendwewell back in
getting into the trunk
Its hard to tell in the pic, but this is down under the floor line
1/0 ran into the trunk under the backseats, through a passage into the trunk, look its gone!
lol
wire slowly disappearing
and now the wire has been Houdini 'd
power wire ran,, and gone, battery area which has cover, this will all be gone also, this pic is not 3D so you cannot see the depth and contours this wire is on, i will try to get a side pic
