spoke with jeremy at kicker. he is almost certin that replacing just the negative batt terminal to the chassis with 4ga wire would allow more current and in return keep voltage steady. he also said the 50 amp fuse mightve been starving the amp somewhat and to keep the 80a fusw in since it somewhat "fixed" the issue! stock wire 8 or 10 gauge like speaker wire and its stock so mabye doubling it up with 1 out of the big 3 will help me get back into the 12v range when at full tilt? does this make any sense to yall bAss headz?!
so this guy once ran out of his house screaming "your bass invaded my home and disrespected my family" lmfao smh gotta love tha compliments !!!
1997 Lincoln TownCar
Old Sony Deck
1 Kicker cvr15" Factory ported box
Kicker zx750.1 (Ix500.1) in closet lol
everything else is stock for now...
Besides "Big 3" thats done :)
btw the amp has that f.i.t technolgy shit where if it dips below 11.5v low voltage light will flicker like mine. if it gets down less then 10.5v at amp it will shut off into protection mode. im hoping this wiring kit by knuconcepts will do the trick! id hate to have to send the amp to oklahoma lol
Old Sony Deck
i cleaned ground real good used star washer ect. n its a kicker ix500.1 class d amp and thanks for welcoming me bro! good to be here
Old Sony Deck
naw really clippin bro. i understand you really cant hear clipping tho my gains are set less tha half boost b.s. off mode and im almost garunteed its just low voltage due to those 15 year old speaker wire sized shitty stock electrical wiring... like i said i got warranty a year on sub and amp just in case sonethibg fvcks up but them amps are smary. when they see clipping or less then 10.5volts. it goes into sleepy mode haha
Old Sony Deck
and i believe last time i had dmm on deck it read like 12v at amp
thats when i had two comp 15s wired parrelel to 2ohms
it would drop yo tenish an shut off protection mode. come to find out
one of the comps had a blown vc which in return
im guessing would cause lower impedence less then
2ohms and amp would do its job and go safe mode.
it sounds good now. dont cut out. bumps nice. just gettin
into the 11.5ish range when heavy bass hits so hopefully
big 3 will help. ive heard just the neg batt post to chassis
can get chu a .5 of a volt increase!
Old Sony Deck
kicker suggested upgrading just that wire
but might as well do all 3 dont seem to hard on my towncar
the neg batt wire (not one grounded at body) runs behind
engine by the firewall.. looks like a bitch to get to
but ill just get my.creeper n floorjack out lol
Old Sony Deck
ill take pics here shortly of electrical wiring if it helps thanks bud
Old Sony Deck
bump?! i noticed i had a parastic drain on battery
i been trying to narrow it down n today i opened my trunk and the bulb was blazin hot. stuck relay? i removed the hot ass bulb but voltags problem continues.. im taking my walmart battery back amd demanding a cash refund instead of exchange so i can get a kinetik hc1200 or a yellow top .. along with a 0 or 4 gauge wiring kit for my big three upgrade. i chose a knuconceptz kit. seems legit! Any input?!
Old Sony Deck
  • Who's Online   1 Member, 0 Anonymous, 1694 Guests (See full list)
