Routing a rear view camera, which path?
Im installing a rear view camera.. and cant determine which way I should route it? With the power/ground side or the RCA side?
I think i should go RCA side so there isnt any videa noise, but the wiring for the camera is as followed:
from radio rear port - 12 v power/ground wire, then it goes to a video box converter, then theres a wire on the other end of the video box that acts as rca connectors, which then routes to the rear where the camera is located. Will the 5-6 feet of power/grnd cause noise if ran by my audio systems rca's? Or will my camera rca be affected by the 0 ga power ground if ran on the other side?
Run it same side as the RCA's. and power/ground behind the radio won't hurt anything.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Thanks, That confirms my first idea of how I was going to attempt to route it. To try to use the rca of the camera for most of the "run" as possible. And bind the rest towards the head unit.
  • Who's Online   1 Member, 0 Anonymous, 1365 Guests (See full list)
