pimpnFosgates Posted May 23, 2013 Report Posted May 23, 2013 ok so i have an aftermarket alternator that will drop into my cabby but its built for a 96 suburban with a 5.7i need to know how to wire this alternator up. other than the bolt that runs the leads for my batteries i dont know where to run the wires. its a 4 term connector but im 90% certain i dint need to use all 4. i really think i only need to use one but alas, im not certain. the 4 wires coming off have letters underneath them that arePLFSmy guess is F is for FieldS maybe to starter?but im not certain.can anyone here help me. the 96 suburban only had one wire coming off the connector but i dont know which pin or to where. i havent been able to play with my buddys burban in a while.Please help and thank you. and its not stock on a suburban. its a handbuilt alt. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
pimpnFosgates Posted May 24, 2013 Author Report Posted May 24, 2013 noone Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
purplesyrup Posted May 24, 2013 Report Posted May 24, 2013 Did you try googling it? What is the make of your car? Porsche? If it is you will likely have to ask a porsche technician and if it is a porsche are you putting a system in the front trunk?
CoritaAlterado Posted May 24, 2013 Report Posted May 24, 2013 P= StarterL= Regulator F= Field+ S= Sensor Edit: Ok so there's PLIS and PLFS alts. PLIS is usually in a vehicle with a BCM, PLFS is usually in one with the BCM. From what i read they're not interchangable so you have to get the correct one. So you're trying to put a alt that belongs in a suburban into a Cabriolet?
pimpnFosgates Posted May 24, 2013 Author Report Posted May 24, 2013 ya its an aftermarket 350.really trying to find if possible and how.my lil vdub needs more juice!fuel injected.the burban only ran a wire the started and its a system in the rear Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
