dl9890 Posted May 23, 2013 Report Share Posted May 23, 2013 Will subs clip if they are in a box that is too small? I have my SDC's 12s in a prefab (All I got right now) and they start clipping when I turn them up. Link to comment Share on other sites More sharing options...
CleanSierra Posted May 23, 2013 Report Share Posted May 23, 2013 How do you know they are clipping? You have them hooked up to an oscilloscope? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
dl9890 Posted May 23, 2013 Author Report Share Posted May 23, 2013 Well when I turn them up they cut out. Link to comment Share on other sites More sharing options...
flood77 Posted May 23, 2013 Report Share Posted May 23, 2013 clipping is distortion,sounds like you have a diiferent problem like the voltage running to the amp Link to comment Share on other sites More sharing options...
CleanSierra Posted May 23, 2013 Report Share Posted May 23, 2013 Amp settings are what will cause you to clip. The enclosure does play a role in this as well. How were your gains set on this amp. Typically prefabs don't have much port area, or proper volume. Easiest fix is to get someone to set those gains correctly And the SECOND you can, get a custom built enclosure. Plenty of guys around, including myself, that will help you with design and cut sheet Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
dl9890 Posted May 23, 2013 Author Report Share Posted May 23, 2013 I set the gain on the amp myself. I just turned the radio volume to about 28 and adjusted the gain until it sounded distorted. Seemed to be the logical thing to do sense I don't have anything to properly set them. Link to comment Share on other sites More sharing options...
CleanSierra Posted May 23, 2013 Report Share Posted May 23, 2013 But as far as clipping goes, your ears can't hear clipping. They can hear distortion, but not squared off sound waves. The cutting out,I assume, is your amp going into protect. That or you have a bad ground location. Advice: locate someone on the forum in your area to set your gains for you. What amp are you using if I may ask? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
dl9890 Posted May 23, 2013 Author Report Share Posted May 23, 2013 Yeah that is what's happening, the amp goes into protection mode. I'm using a DX1000.1 Link to comment Share on other sites More sharing options...
CleanSierra Posted May 23, 2013 Report Share Posted May 23, 2013 And which voice coils do you have? D4s or D2s? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted May 24, 2013 Report Share Posted May 24, 2013 Your cutting out could be due to a couple factors. Voice coils wired wrong, wrong voice coils themselves(example D2s wired at a.5 ohm load at the amp), or bad grounds causing the amp to protect. There are many factors that can cause your issue. Bad and insufficient voltage is one big one. Gain setting is another, you're going to want that set with the right equipment. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
