Hi
Just fitted a Viper 5701 into my VW Golf
Wired the aux 1 to a relay, So i can have the headlghts on a timed 30 second input.
However when i activate aux there is no voltage on the aux wire.
Is there anything that has to be done first?
To try activate aux1 i press the F button once then press aux.
It plays the tone but when i test the aux wire its always at 0v
what wire(color)are you using ? did you change it in the programing menu for 30 seconds opt 4? i think it comes programmed to only output power for as long as you hold the aux button down?
Thanks
I wired the relay for a switched +12v output, I have now rewired it for a switched negative and all is working now.
Also i have changed the aux output mode to 30 second times
And also linking with arm/disarm
