Reed Farrar Posted June 19, 2013 Author Report Posted June 19, 2013 How's Ur voltage now? my voltage is alot better but it still isnt the best. my alternator is seriously messed up. my voltage never goes under 12 volts but i was hoping for it to never go under 13 but looks like i gotta get a mechman alternator before i plan on buying my highs amp. The only way to stay in the 13+ volt range is to never exceed your alternators output capabilities. For example if you have a 5K watt amp then you would need at least 550amps of alternator power to stay above 1 How's Ur voltage now? my voltage is alot better but it still isnt the best. my alternator is seriously messed up. my voltage never goes under 12 volts but i was hoping for it to never go under 13 but looks like i gotta get a mechman alternator before i plan on buying my highs amp. The only way to stay in the 13+ volt range is to never exceed your alternators output capabilities. For example if you have a 5K watt amp then you would need at least 550amps of alternator power to stay above 12.9v. im thinking about getting a mechman 170 amp. you think that would be alright to have "2400" watts on? Quote
