XS Power
How's Ur voltage now?
my voltage is alot better but it still isnt the best. my alternator is seriously messed up. my voltage never goes under 12 volts but i was hoping for it to never go under 13 but looks like i gotta get a mechman alternator before i plan on buying my highs amp.
The only way to stay in the 13+ volt range is to never exceed your alternators output capabilities. For example if you have a 5K watt amp then you would need at least 550amps of alternator power to stay above 1
The only way to stay in the 13+ volt range is to never exceed your alternators output capabilities. For example if you have a 5K watt amp then you would need at least 550amps of alternator power to stay above 12.9v.
im thinking about getting a mechman 170 amp. you think that would be alright to have "2400" watts on?
