Wow!! I grew up on low riders and this clear pumps and ... I dunno even what to say. Amazing custom work that's the prettiest trunk I've ever seen.
that's some really clean and sexy work there.
how'd you go about making the led's change color to the music?
This is similar to what I used, plus some rgb SMD 5050 led's
http://www.ebay.com/itm/DC-12-24V-12A-IR-Music-LED-Controller-for-RGB-5050-3528-SMD-LED-Strip-/181265433702?pt=US_Lighting_Parts_and_Accessories&hash=item2a34430466#&panel1-3
hey im trying to build a whammy tank what size pipe do i need to use to replace the tanks?.....
The clear tubing comes in od inch increments only, standard tank size is about 5 1/2" ID, which is not available. I used 5" OD and machined the sealing plate to size..
took a good look at this at the super show....that set up is crazy! Porting to the pumphead and using an external oil tank instead of using the tank on the pump so you could keep it clear and not fill it was a sick idea. The engravings came out awesome!
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
Thanks homie..Our plan was to have oil in the pump tanks also, just used the external so the clear tank oil wouldnt get dirty.. But we ran into some last min issues before the supershow with the back plate, so didnt want to risk having leaks at that point.
In all honestly I think it actually turned out better that way than having the oil in the tanks! Shows off the engraving work on the motors better too!
Who did the engraving and hard-lining? I like how it was kept simple, but still shows accents the set-up nicely!
hey one more ? how can i hide rear cylinders under the bed of a 80s box body ranger. ive seen it done on a few elco's and bomb trucks but cant see how its done
b8426b6f-6b19-45b2-aa60-f898a05a3587_zps
88 ranger xlt ext cab
HU. jvc bluetooth/usb deck
mids/highs. 2 earthquake 5s. 2 earthquake 6s and 2 Cadence CVLT-60 tweets
subs. 2 Addictive audio V4 12s
SAZ3000D
SAX100.2
alt. 135 amp ford mustang
batt. deka G31 1131MF
box. 4 cubes 30-34hz
rims. black 13x7 100 spokes with chrome knock offs.
tires. 155/80r13.milestar touring se
real billet grille not a bolt on.
HYDROS FINISHED!!!!! 2 pumps 4 batts
I get fucked by this old guy at work all the time. MY ASS WILL FOREVER REPRODUCE THE LOWEST AUDIBLE SUB BASS FREQUENCIES KNOWN TO MAN!
just because we think it ugly and it sounds like a bucket of smashed assholes.
Hanes. And dried jizz. It's better than fatmat
I have an engraver here in Houston and one in Dallas, they are both really good and it's all done by hand. I do all the fabricating, welding, molding, hardline, paint, and design. I pretty much do everything exempt engraving and upholstery.
To hide the cyl I usually put them upside down using a power ball. Mount powerball as high to the bottom of bed as possible, but not tdc of axel, just behind it so the cyl will hang behind the axel and you can make a bracket off it. Use the coil over technique, usually a mini coil is easiest.. The longest cly you might be able to use is maybe a 10" depending on how low you plan to sit.. I would post a pick to help but I don't have any at the moment.. Sorry
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
