To Good To be True???
PeteSiebenand
ok so ive seen some ads for this amp.
Spec:
  • Maximum Output Power: 1 x 1000 W (4Ω) or 1 x 1600 W (2Ω) or 1 x 2400 W (1Ω)
  • RMS Power: 1 x 500 W RMS (4Ω) or 1 x 800 W RMS (2Ω) or 1 x 1200 W RMS (1Ω)
  • Frequency response 10 - 240 Hz
  • Distortion 10 W, 100 Hz ref. < 0.5 %
  • S/N ratio > 100 dB
  • Bass Boost: Remote Control, Frequency 50Hz, Level 0-18dB
  • LPF 40 - 240 Hz (-12 dB/oct)
  • RCA Input terminals
  • Speaker Terminals Block-type
  • Speaker line input sensor Turn-on sensor
  • Input level control RCA (0.2V - 6.5V), SP (0.8V - 16V)
  • Max. current consumption (A/4Ω) 39 A
is it to good to be true that i can get a 1200w RMS@1ohm amp for this price?!?!! (267dollars)
has anyone got one?that lives near SMD HQ that would let steve test it on the bench??
cheers in advance
if not, what amp would you guys recomend, im not after pure SPL more SQL with the ability to go hard/punch/go deep
In my experience, Pioneer amps aren't bad (persay). But if your looking for TRUE RMS or good numbers, go with a Rockford Fosgate, DC Audio, or Sundown amps. They may be the preferred amp for SPL but when numbers matter, the numbers don't lie. And you'll get better SQL out of an amp that can do the work, than an amp with low numbers that struggles to keep up.
I assume your looking for a cheaper amp? Audiopipe 1500.. $188 on eBay
http://item.mobileweb.ebay.com/viewitem?index=0&sbk=1&nav=SEARCH&itemId=251143349183
Edit: I've owned two. Seem to perform well
id love to buy this, BUT im in the uk.
but 1200w rms, i dont really need it, im not after 1200w, but the extra overheads nice. ill probably be running a single 12" Alpine Type X/new Type R.
  • Who's Online   0 Members, 0 Anonymous, 1778 Guests (See full list)
