I thought it was ring terminal on bottom, nut, fuse, washer, lock washer, then nut? atleast that's how we do it.
*edit* just noticed the nut is fixed on the bottom, so ignore ring terminal on bottom.
I'd almost be willing to bet money this is your problem... because you have it going nut, washer, ring terminal, lock washer, fuse, washer, and nut.
ok in this case it should be, nut on bottom (of course), fuse, ring terminal, washer, lock washer, then nut
So its the orders of my washers and nuts that fucked up my entire system?
probably not unless they were arching somehow
So... back to the drawing board I guess. Also, would I need to upgrade my 300a fuse when I put my second sundown1500 in?
is the power wire heating up???
seems like there is a lot of resistance at the fuse holders and battery terminal...heat is simply caused by resistance
Could it be the connections were soldered with the wrong type of solder? Or solder is the same no matter what right? Thats the last thing I can think of that would cause resistance at the battery and up front. I did take off all the washers and just put the fuse with the two lock nuts and tightened it down real good and I have had no problems... Yet.
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
