datboilos913 Posted July 3, 2013 Report Posted July 3, 2013 So I started to tub out my trunk seen it done on a video thought I would try it seemed pretty easy so I did it cut out my templates for windows, to show the amp and the speakers than I put the fleece on it than I streched thru the the rubber weather tripping on the car tapped it off and began my fiberglassing let it set up and than I started putting on some chop mat. Put about 3 layers on and than i let it dry once it was dry I pulled it out and renforced the back of it and trimmed it down and started to body work it and cut out the holes for the trunk hinges and got it wraped in vynal to match the rest of the interior but now I went to put it in and it just falls in and I have no way to keep it from falling down into the trunk can anyone tell me what I didnt do orcwhat I should or could do now to fix the problem any help will be great thanks
mrd6 Posted July 4, 2013 Report Posted July 4, 2013 Some pictures would help alot. I have no idea what "tub out a trunk" means. My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
datboilos913 Posted July 4, 2013 Author Report Posted July 4, 2013 I dont know if I can post pics with my phone. I could email u pics if you like
Jskiles Posted July 4, 2013 Report Posted July 4, 2013 use photobucket or some other pic sharing 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
russtezecustoms Posted July 4, 2013 Report Posted July 4, 2013 You should have built a frame under the amps and other things to hold them up to the level you want them at then stretched the felt. You could put a frame under what you have its just gunna be trial and error. Good luck and next time do a search and check out some build logs on here before you jump into a big project like this one. I just wish i had a funny sig.
datboilos913 Posted July 4, 2013 Author Report Posted July 4, 2013 Ok I will make a page and send u the link
datboilos913 Posted July 4, 2013 Author Report Posted July 4, 2013 Thanks that is acttually what I beem thinkin but I will build the support under it now as I have enough space to wok Rk with since I have the two windows I made to show the amp and aubs thanks I will post pics soon thanks again
