Dude. yeah i know that glue is fucked! I plan to take care ot the just about right now lol
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
oh and for house cleaning.... that is clean lol... but I'm the slob lol and I have the cleanest car and my room is always tidy lol wtf? its hard to clean up after everyone else and have a life lol
ok got my baffle installed. got everything primed up should be smooth sailing for the finishing coats letting the third primer coat dry now before sanding and first coat of finish black... should be sexy!
oh and I got the tubing cut for the port I decided to go internal with the port... sitting at about 12 inchs total port length. for a tuning of approximately 35hz. got my old terminal holes covered glued and screwed. so that's done... I may have to trim my baffle to fit the subs in there but shouldn't be too much... pics coming. this evening
quick up dates...
got the baffle installed. ..
port side view
cut my tube to 11 inches for a full foot or assembled actual port length. giving me roughly a tuning of 35hz. duct taped it so I could fiddle with the tuning some
then got ready to paint... I over sand the front and back and made it fuzzy... that was a whore to deal with later but lesson learned.
three coats of primer.
two coats of finish satin black
port side
gently set it in the trunk and put the subs in.... and the port.... the baffle I installed had to be trimmed a little to fit the magnets but I got that taken care of. here's from the port side the port face the passenger compartment. you can see the purple color on the baffle. I'm going to be adding purple detailing too next week end or so I'm pretty excited to see that.
the whole picture... the wires are neater now but I was trying to get everything hooked up before work!
more pics from the sub side later...:D
What's that piece of wood in the way right behind the subs? Is that the piece you're referring to that needed trimmed? If so, that is not a baffle by definition.
yup That's what iwas referring to. I was referring to baffle in the common sense. as to change the flow of a gas or liquid. I didn't want to give either sub a chance to unloa and cause me problems. for that it works well... my buddy said damn that shit sounds beefy lol... also said throaty... so fuck yeah and it'll give the leds something to bounce off lat! r:D
I figured loading was what you were worried about. I'd be more worried about obstructing the rear wave from those subs and getting a nasty byproduct. The port isn't directly behind either sub and I doubt unloading world have been an issue. If anything, I would have placed that piece of wood much closer to the port, than close to the subs like you chose to do.
What was preventing you from forward firing the box with a slot port in the middle? You could have made trim panels to seal it off and everything.
ehh... might do that who knows. I kinda like it this way... its boomy and it sounds decent. though there are other things I'll change in future boxes that's the majority of the reason I built this box was to learn. and the baffle is done such that I can take it out if I want to... but its still in place pretty well so no moving around... ill be tryin stuff out..
