SMZ2 Posted July 13, 2013 Report Posted July 13, 2013 I need some advice on fusing for pure copper flex-a-prene 1/0 welding cable. I will be doing 2 runs of power and 1 to 2 ground runs. I will have a d3400 up front and 3 d3100s in the cargo space and all running on a 270 amp alt. Then off the rear bank 2 skar 2500.1 and a mb quart 125.4. I am also curious how you would fuse these. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
Josef344 Posted July 13, 2013 Report Posted July 13, 2013 Are you running from front battery or the alternator? Chris Brown's build log, prepare for some beating
SMZ2 Posted July 13, 2013 Author Report Posted July 13, 2013 Front battery. What size fuses should I be using? Also how would that diagram look like if I had a bank of 3 batteries? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 13, 2013 Author Report Posted July 13, 2013 My other concern is what size fuses to use with dual inputs My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 14, 2013 Author Report Posted July 14, 2013 Okay so the skar manual calls for a 250 amp fuse. Some when using dual inputs would each positive run use be a 250 amp fuse? Also since my alt is a 270amp should I run a 300 amp fuse on both positive runs? Finally the mb quart amp has 3x40 amp fuse so what size fuse would be used for that amp? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted July 15, 2013 Author Report Posted July 15, 2013 My guesses for fusing please correct me if wrong as I plan to order my fuses and fuse blocks today. 300 amp for each run off the front battery. 125x2 for each 2500 power input since I am doing dual inputs. Then a 125 amp for the mb quart? What if I did dual 1/0 inputs on the mb quart as well though? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
