How An Alternator Works
found this here: http://www.fullsizechevy.com/forums/genera...ator-works.html
Thought maybe it might help someone
Here is a good explanation of how an alternator works:
Alternator Construction and Operation
* An alternator or A.C. generator creates voltage by rotating a magnetic field inside a looped conductor.
Alternator Components
Rotor
* A multi-pole electromagnet that is rotated by a belt & pulley.
* Usually 4 to 7 pole pairs.
Rotor Components
* Winding & Slip Rings
* Magnetic Pole Pieces
* Shaft With Iron Core
Stator
* A circular laminated iron frame that holds the looped conductor.
* An automotive alternator stator usually has three separate looped conductors.
* Each conductor has as many loops as the rotor has pole pairs.
* The current output is 3-phase (3 over-lapping A.C. currents).
Stator Winding Types
* Wye (Y) - 3 looped conductors connected in series. Higher voltage output at low speeds.
* Delta - 3 looped conductors connected in parallel. Higher current output at low speeds.
Rectifier Bridge
* A set of 6 or more diodes used to rectify the A.C. current in the stator into D.C. current before it leaves the alternator.
* The diodes are mounted in a heat sink.
The Charging System consists of two circuits: Output and Field
-Output Circuit:
* The output circuit consists of the stator windings, rectifier bridge, battery and all electrical loads.
* The stator produces current in two conductors during the same time period.
* As the rotor rotates, the stator windings that produces current change every 120 degrees. This produces 3-phase output.
* As the magnetic poles alternate past the loops they produce A.C. voltage.
* The rectifier bridge consists of positive diodes connected to (B+) and negative diodes connected to (B-) in pairs.
* The stator output goes into the bridge as A.C. and leaves as D.C.
-Field Circuit:
* The field circuit may consist of the rotor winding, slip rings & brushes, voltage regulator, indicator bulb and wiring.
* The field circuit controls the current flow through the rotor winding.
* This current is called the “excitation” current.
* Excitation current is provided by the battery before the stator begins producing current.
* The stator provides excitation current after the alternator starts producing current.
Voltage Regulator
* The voltage regulator is part of the field circuit.
* It limits alternator output voltage by controlling the strength of the rotor field.
* The regulator senses battery voltage and controls system voltage to a safe level by pulsing the rotor current.
* Long pulses result in a stronger field and higher voltage output and vice versa.
* Maximum alternator current output is limited by stator CEMF.
* Output voltage will exceed 16V if not regulated.
Field Circuit Types:
-“A”
* The regulator supplies the ground for the field circuit. The other side of the field is connected directly to battery B(+).
* Both brushes are insulated.
* “A” for after rotor!
-“B”
* The regulator supplies B(+) for the field circuit.
* One brush is insulated, the other is grounded.
* “B” for before rotor!
-Isolated
* The ignition switch supplies B(+) to the field.
* The regulator supplies the ground. Both brushes are insulated.
_________________________________
Alternator Output
* Measure current output at the alternator B(+) wire while loaded to 12V at 2000rpm.
* Should be within 10% of rated output.
* Example: Alternator rating; 120 amps Tested output should be 0.9 x 120 amps = 108 amps minimum
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 4697 Guests (See full list)
