97EK Posted July 21, 2013 Report Posted July 21, 2013 Hello guys, I'm new on here and relatively new to car audio. I recently picked up 2 sa-8 v.2s and want to maximize the sound I can get out of them. They are going in a 1997 civic that I have take. The rear seats out of and dynamated on every square inch of the car, there is also about an inch of carpet padding under the carpet for added insulation and polyfill in the rear fenders. The trunk is blocked off with 1.5" of MSG, dynamat, and insulation as well as silicone sealant, I plan on using the backseat as the place for the subs and literally have no limitation on size of box. I don't mind making complicated boxes, I can do 1 or 2, whatever works best. I don't want the setup for burps, but I do want to be able to blow away my passengers. The subs will be running a steady 600 watts rms each, any other questions can be answered. I need all the experts out there to help me out and make my project their project. Please help me!! I do understand most simple car audio concepts and have built boxes before, I just don't have the skill to design an amazing box and that's where you guys come in. Even just tips are much appreciated. Thanks!!
reg93f150 Posted July 22, 2013 Report Posted July 22, 2013 Put your max dememsions, what type of music you mainly listen too and what amp your gonna be powering the subs with I'm not really one to design boxes for others but there's plenty of others on here that can help more then I can, but that will help them out with designing the box. Good luck man! ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
97EK Posted July 22, 2013 Author Report Posted July 22, 2013 Max dimensions <41" w <24" d <28" h Powered by kicker kx1200.1 I mainly listen to rap but would still like to be able to keep up with fast paced pop and rock. Thanks!
