79 cutty Posted August 1, 2013 Report Share Posted August 1, 2013 http://mobilesolutions-usa.com/smartparts/mekpdispensers_1.htm Here is what I am talking about, and I am sure if you did some searching you could find them cheaper if needed. A world of a difference instead of counting drops!!! Firm believer in letting my cars do my talking! You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it. "Black Pearl" Build Thread http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1 Link to comment Share on other sites More sharing options...
Jessica Posted August 1, 2013 Report Share Posted August 1, 2013 http://mobilesolutions-usa.com/smartparts/mekpdispensers_1.htmHere is what I am talking about, and I am sure if you did some searching you could find them cheaper if needed. A world of a difference instead of counting drops!!! I need to invest in one of those. But i have found a way to cut costs. Wal mart sells plastic measuring cups with ounce marks on them in the paint section. I used to re-use those till they broke but i found some cheap clear plastic cups, like 100 for 2.48 that hold up to the heat of the resin. i measure in cup that has the marks and pour it into the cheap cups and add my catalyst. Keeps my measuring cup clean too. I still go through a ton of those $1 2" brushes though lol. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted August 1, 2013 Report Share Posted August 1, 2013 I've been doing a bit of fiberglassing lately. I'm no expert but I have noticed that the directions say mix X number of drops of catalyst with X ounces of resin. The problem is, what is a drop? Are you going to use a straight pin to puncture the tube, the tip of a screw, nail? If you havent used fiberglass before make a 2 ounce batch. mix pre directions and just work with it nice and slow and see how long you have before it starts to gel up. My resin calls for 10 drops per ounce, but it's 85+ out and i use about 7-8 drops per and i have time to get it worked in, the 8 ounce batch i made today i had just enough time to get it all worked in. Hope that helps Since its a ratio, it shouldn't matter the size of the drops, as long as they're the same. Just use he same screw to make all of your holes and you should be good one would think. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
Jessica Posted August 1, 2013 Report Share Posted August 1, 2013 Bigger drops mean more catalyst, smaller drops mean less catalyst. But that is a discussion for a different thread. We are starting to derail this one. Sorry OP. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
79 cutty Posted August 1, 2013 Report Share Posted August 1, 2013 http://mobilesolutions-usa.com/smartparts/mekpdispensers_1.htm Here is what I am talking about, and I am sure if you did some searching you could find them cheaper if needed. A world of a difference instead of counting drops!!! I need to invest in one of those. But i have found a way to cut costs. Wal mart sells plastic measuring cups with ounce marks on them in the paint section. I used to re-use those till they broke but i found some cheap clear plastic cups, like 100 for 2.48 that hold up to the heat of the resin. i measure in cup that has the marks and pour it into the cheap cups and add my catalyst. Keeps my measuring cup clean too. I still go through a ton of those $1 2" brushes though lol. Well from the sounds of it sunflash should take care of the brush issue. Firm believer in letting my cars do my talking! You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it. "Black Pearl" Build Thread http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1 Link to comment Share on other sites More sharing options...
