_94fleet Posted August 2, 2013 Author Report Posted August 2, 2013 Read voltage at the battery with the DMM, then move the negative probe to your ground point and leave the postive on the battery positive, voltage should be exact same, if not bad ground, move ground, clean to bare metal and make it tight. If you can move the terminal it is a weak connection. B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
