q1-3500 grounds
so my batt in the trunk is grounded to the trunk floor and amp to batt. i got about .5 resistance on that ground. should i replace or just leave it and add a run to the front batt? im also curious what bad could this gnd be doing if any? i havent had any issues yet. just surprised amp hasnt blown fuses since it only has 160 amp worth of fusing and sounqubed says to use 380.
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
Ground your battery to the strut tower, ground the amp to the battery.
And touch your leads on your DMM together. What do they read?
no strut tower. rwd. it read like .2 but i had already took that into consideration. also should i have 2 gnds since the amp does?
1994 cadillac fleetwood
Perhaps you may be better off grounding to the frame of the car vs.the body?
most likely. a shop installed all my stuff so im not sure whats good. so if it was a bad ground how would i know? like i said i dint have any issues but im not sure if it would rob the amp of some power.
Read voltage at the battery with the DMM, then move the negative probe to your ground point and leave the postive on the battery positive, voltage should be exact same, if not bad ground, move ground, clean to bare metal and make it tight. If you can move the terminal it is a weak connection.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i will try that. i have some dual inputs i really want to throw in there. you think any protection is needed so nothin garcs them since the neg and pos are right next to eachother?
i just checked real quick and i cant easily get to my batt but my amp reads 13.12v and the gnd comes up at 13.11v.
  • Who's Online   0 Members, 0 Anonymous, 2307 Guests (See full list)
