fox_racin4 Posted August 2, 2013 Report Posted August 2, 2013 Its 6 screws to change a basket When you do the recone, what i do is i place enough ... Shim.. To make it hard to slide the drop in, in that way you lnow forsure that its 100% center. You want shims atleast 33* apary or 90* ( so 3 or 4 shims, however thick you end up needing) 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Cox Posted August 2, 2013 Author Report Posted August 2, 2013 Its 6 screws to change a basket When you do the recone, what i do is i place enough ... Shim.. To make it hard to slide the drop in, in that way you lnow forsure that its 100% center. You want shims atleast 33* apary or 90* ( so 3 or 4 shims, however thick you end up needing) Alright thanks for the help. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
