3000 Watts for $300 - To Good to be true? BB5000D AD-1 Results
We did AD-1 it at a half ohm, it never got warm or went in to protect. I'd be confident running it safely at a half ohm with a decent charging system
The run at .5, then wasnt in certified.. cuz it WOULD protect there....
It took certified at .5 just fine. I'm not posting that in the video because Belva doesn't say they are stable there and I'm not trying to have some idiots on stock charging try and do that.
Build In Progress!
2000 V6 Mustang
H/U - JVC KW-ADV64BT
8 - P3D212's / 14cu. ft. / 34hz
Front - T1675x2, PPS4-8x4, T1TSx4
Rear - T1675x2, T165x2
Sub Amps - T2500-1bdCPx2
Mids/Highs Amps - T600-4x2
3SIXTY.3 Signal Processor
51Ft. RF 1/0 Spool x 2
Excessive Amperage 300amp Alternator
VMAX CT2500 x 2
Optima Yellowtop
Man.. cool.
I spoke with Tony, and a certifed .5 test, would protect 99% of the amps on the market....
ScreenShot2013-08-15at62350PM_zps5a6d71e
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
Regardless, for a cheap amp that is only $300, 1700 certified amp dyno watts is legit for an amp that is so inexpensive, it probably has a decent warranty also.
I mean, seriously, try to make a list of $300 amps that do 1,700 true unclipped watts at 12 volts
You can see my list below,
:shrug:
  • Who's Online   0 Members, 0 Anonymous, 1366 Guests (See full list)
