Thinking of upgrading my system- need help!
Hey Im currently running 2 Kicker Comps 15's pushed by a Kenwood 1000 watt. Im thinking of getting 2 RE SEX15D2 15's. On a small budget, the subs are like 315 bucks for 2 of them at audiosavings.com I saw a DB Bass infero 3000 watt amp for 150 bucks. Anyone know if I should trust it? and should make a custom box or buy one off the web? Will i need a new battery/alt.
Just need some help thanks!
http://www.ebay.com/itm/BASS-INFERNO-by-db-Drive-BI3000DX-3000W-MONOBLOCK-CAR-AMPLIFIER-AMP-BI-3000DX-/171058472652?pt=Car_Amplifiers&hash=item27d3e126cc on the pic´s you can see that the amp have 3 40 amp fuses. 120 amp of fusing is a sign for arround true 1200 watt RMS, that doesent
mean that these piece of crap do 1200 watt´s, it´s only a sign.
In the linked wiringwizzard http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3 you can see you can wire
2 D 2 sub´s to 0.5 Ohm 2 Ohm or 8 Ohm. If you buy 4 Ohm sub´s you can wire to 1 or 4 Ohm. On your side i would buy D4 sub´s. It´s cheaper to find a
amp that does 1.2-1.5 K watt RMS (SEX sub is a 600 watt RMS subb) @ 1 Ohm than a amp that does this on 2 Ohm.
As amp i guess you http://www.onlinecarstereo.com/CarAudio/p_23923_Hifonics_BRZ17001D.aspx, be quick there are the last on the market.
They do what printed on them and they aren´t extrrem dirty in power.
Get the biggest baddes´t AGM batt that you can fit under the hood. If you have only place for a small batt under the hood. Buy a 100+ ah AGM batt for in the trunk.
"in the abundance of water, the fool is thirsty" Bob Marley
Ok here is my opinion. The re sex are not bad subs I have herd a 12 and it sounded ok for what it was in(demo wall for re audio). Now second what type f car do you have. Third dont get that amp. I would buy the soundqubed 1200w amp. It's proven to do rated and with that you should be able to get away with doing the big3 and a batt in your trunk. As for box NEVER buy a prefab build a custom one or call some one who will do it for you like Dave the box guy
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   0 Members, 0 Anonymous, 594 Guests (See full list)
