Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 Im not the one you want to try to troll. Just a fyi for you. Fyi,IDC who you r bro member, mod, police, feds, president. this forum does not matter to me that much! fyi if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 okay. the amp is 2 amps in 1. 2 of their shitty 1500's to be exact. they're strapped internally. hence why its only stable down to 2 ohms because each of the 1500's will see 1 ohm. $300 for 2000 watts of shitty power at best. with a 200 amp fuse. ide more of say 2400? also to you, why wouldnt i know that its 2 1500's???? i think 300$ is still worth looking into it before i bought it, but i dont think 300$ for 2400 rms is not too bad if it is im not looking in the right spots for the right deals. also to anybody out there. why would AP continue to edit and change the look of an amp that is no good? answer me please? why would they continue to edit the casing to make it look different? because stupid people buy those amps still. a guy clamped his 1500 at like 1000 watts. fusing doesn't necessarily mean it'll output X power. meade did an amp dyno on some crunch amp or something that had 70 amps of fusing and only did like 350 watts. and i'd rather spend my money on a good korean amp because my audioque made my woofers sound much better than that piece of shit audiopipe that blew up on me when being fed 14v with no drop. i dont see how it blew up at 14v? my stock alt charges around that . so i get it. sounds like a miss wire or something??? and was it the ap30001d? because its a shitty amp! what else do you expect. my wiring didnt change whatsoever when i switched over to the audioque 1200 and its been working for years. i had the ap 1500, which is the same exact thing as the ap 3000 which just literally has 2 1500's internally. edit: while it was blowing up (aka shorting out internally), it dropped my voltage below 9v, which caused everything electrical in my car to turn off. hid's, radio, dash lights, volt meter, everything. i dont even know how the car was still fucking running at that voltage. i literally heard mini fires start inside the amp, which was verified because the bottom amp cover was burnt as shit. mind you, this was like 11pm driving through town. not enough power to the amp if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
CleanSierra Posted August 29, 2013 Report Share Posted August 29, 2013 Im not the one you want to try to troll. Just a fyi for you.Fyi,IDC who you r bro member, mod, police, feds, president. this forum does not matter to me that much! fyi ANNNNNNNNND game over. I tried to save you from yourself Kasey, but you can't fix stupid. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 Im not the one you want to try to troll. Just a fyi for you.Fyi,IDC who you r bro member, mod, police, feds, president. this forum does not matter to me that much! fyi ANNNNNNNNND game over. I tried to save you from yourself Kasey, but you can't fix stupid. dude. itss ok . i will live love and work like ive always done before i became a forum noob on this site man. thats the thing. it can help me or i can do without. also. cant fix a amp u blow up because u dono what your doing! if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Guest Posted August 29, 2013 Report Share Posted August 29, 2013 LOLOLOL NOT ENOUGH POWER BUT I WAS HOLDING 14v. do you even logic? Link to comment Share on other sites More sharing options...
Guest Posted August 29, 2013 Report Share Posted August 29, 2013 I'm so done in this thread. op is unfixable Link to comment Share on other sites More sharing options...
CleanSierra Posted August 29, 2013 Report Share Posted August 29, 2013 Well, he kind of dangled his bleeding arm in front of a shark. Not one of the smarter things to do... P.S. I DOOOO have him to thank for my purty new sig Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 29, 2013 Author Report Share Posted August 29, 2013 LOLOLOL NOT ENOUGH POWER BUT I WAS HOLDING 14v. do you even logic? there for AP is a pos brand with false advertisement as up to 16v right on the amp! and never been sued about it! got to at least give them that? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
JcbPrry Posted December 9, 2013 Report Share Posted December 9, 2013 Dont forget the trunk fire because of an ap amp lmao 2004 Ford Taurus Kenwood KDC-352U Dash Kenwood (2) 6x8's 2 American Bass HD 15's D1 Coils Audiopipe APK3500.1 @ 1ohm Shuriken SK-BT140 Battery 8.8cu box with two 6'' aeroports, firing into the cabin All Audiotechnix 0awg Link to comment Share on other sites More sharing options...
