Hammer Knock Posted August 22, 2013 Report Share Posted August 22, 2013 with the new single speaker terminal on the apcl30001d,(compared to ap30001d) is it still 1 ohm stable??? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
2loud4uboyz Posted August 22, 2013 Report Share Posted August 22, 2013 It's 2 ohm Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 22, 2013 Author Report Share Posted August 22, 2013 if i remember. i had it at 1 ohm on my 2 lanzar opti 1233d and it was before i had the dd-1. and i didnt know so i put them to 4 ohm. getting much less from my amp at that. so wondering with the single port. did they bridge it or whats it wired as now? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
jarrius Posted August 22, 2013 Report Share Posted August 22, 2013 Output Power (RMS): 1800 Watt x 1 Channel @ 4 Ohm 3000 Watt x 1 Channel @ 2 Ohm 2 x 3000 Watt @ 1 Ohm 6000 Watt MAX MOSFET Power Supply 1 Ohm load stable overload protection I would say yes but good luck getting 3k out of it And it's a mono block so no bridging what you hook up to it is what it sees 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 22, 2013 Author Report Share Posted August 22, 2013 so thats 1500 each sub at 1ohm ya? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
jarrius Posted August 22, 2013 Report Share Posted August 22, 2013 If you bleach that. I can almost guarantee you the amp will not give you that much power 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
Hammer Knock Posted August 22, 2013 Author Report Share Posted August 22, 2013 bleach? lol if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
2loud4uboyz Posted August 22, 2013 Report Share Posted August 22, 2013 take back comment Link to comment Share on other sites More sharing options...
breeze919 Posted August 22, 2013 Report Share Posted August 22, 2013 No, It's still only 2-ohm stable. Written write above the speaker terminals. 2002 BMW 530i [E39]|Headunit: Pioneer AVH-4300 ||Front Speakers : Diamon Audio 5.25 Components||Amps: Pioneer 4 Channel & AP30001D ||Subs: SSA XCON 15 ||Box: 4.3 Cubes @ 30hz| Link to comment Share on other sites More sharing options...
jarrius Posted August 22, 2013 Report Share Posted August 22, 2013 If you bleach that. I can almost guarantee you the amp will not give you that much power Believe damn iphone lol 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
