FS : (2) Sundown SAZ-1500.1Dv2 Amplifiers - $315 EA Shipped
1. Product:
(2) Used Sundown Audio SAZ-1500.1Dv2 Amplifiers
2. Specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm <0.1%
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
3. Description/Condition:
Both are used but in good condition and work perfectly. The only thing worth nothing is that one of the 2 amps has a missing set screw, but that is all! Great deal on 2 amps here. Same price shipped for each.
We got these in on trade for some Skar Amplifiers which is why they are for sale - we tested them in house and they work perfectly!
4. Price: :
$315 Shipped Per Amplifier via UPS Ground. First come first serve. PayPal [email protected] and we will ship it same day UPS Ground and send tracking.
5. Pictures:
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
For some reason the photos are no longer working in our original post so we are going to post photos now of the one amp we have left
Skar Audio
www.SkarAudio.com
