'05 Ford Escape Limited *SKAR AUDIO BUILD*
the fact it did a 49 in that box is impressive. I'm not building for numbers at all. A 4th order requires too much space for me to build using 4 15s in my c pillar wall area
Deck: Kenwood DNN990HD
Front Stage: (6) 8" Skar Audio PAX-8 Pro Audio Speakers - 3 in each front door (4) 1" Skar Audio VX1-ST Bullet Tweeters - 2 in each front door
Subs: (4) 15" Skar Audio VVX-15v2 Dual 4s wired at 1 ohm
Sub Amps: (2) Skar Audio SK-2500.1
Mids/Highs Amp: (2) Skar Audio LP-80.4 - powering mids/tweeters
Wire: (4) runs of 1/0 cable front to back, T SPEC V12 RCA
Batteries: (5) group 34 batteries - 1 up front, 4 in back
C-pillar flat wall
Buid Log: http://www.stevemeadedesigns.com/board/topic/174250-05-ford-escape-limited-skar-audio-build/
If I missed it my bad but any HO alt?
I've also got an 05 and wondering if you had any luck with one.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
Not yet, haven't really looked into it either. I'll be contacting Mike Singer for the alt when its time though.
As far as doing an alt in an escape of this body style, its a time consuming job to say the least. I've done 2
C-pillar flat wall
I have done one also and yes it's time consuming. Good luck and lmk if you get a singer.
05 Escape
1/0 SHCA OFC
Pioneer 80 Prs
Pac
Prv mids and highs
Came across a few deals I couldn't pass up lately, got 15 sheets of 1" mdf for a steal of a price, 500ft of 14 awg speaker wire, and hopefully today I'll be grabbing 20ft of 2/0 monster cable power wire.
Ideally for now I'd like 4 runs from front to back, 2 power, 2 ground. then I'll start my deadening most likely going with ct sounds deadener now.
1507043_10151915809788041_2049859186_n_z
C-pillar flat wall
small update, got some donor panels so I can start work on them, pulled the box out to start the build on the wall shortly, and got a couple batteries will be adding another one, possibly 2 more haven't decided yet.
Batteries are basically second strongest batt to a odyssey 2150 fully sealed agm batteries, deka group 31. 850cca and 65 amph with dual marine posts. @ $125 each I grabbed two for now.
Pulled all my gear out including the back battery yesterday and noticed the front battery has been completely dead so I had to throw the universal big battery back in for now tempoarily
1558749_10151921325273041_2111976731_n_z
1600023_10151921325258041_1757313305_n_z
1555630_10151921325268041_655303008_n_zp
1533368_10151921325278041_841860392_n_zp
1558901_10151921325283041_119091509_n_zp
C-pillar flat wall
not really liking the quality my iPhone 4 is producing with these pictures, sorry guys.
C-pillar flat wall
Started the wall build today, going to go over with it and build the rest using PL for now, far better quality glue imo. Also looking into the AirLift 1000 spring helper bag setup. Basically its a bag that presses into the coil spring runs off a valve you can connect air supply to and set the ride height as desiered to keep from sagging. I read quite a few reviews which all seem to be okay, and for the money I think I'll give it a shot.
Anyway heres a few progress pics for the build thread.
1533193_10151923579678041_472020908_n_zp
1598334_10151923579693041_1131473911_n_z
1600016_10151923579683041_1745379962_n_z
1600200_10151923579688041_1828711669_n_z
And the airlift system I'll be ordering shortly:
http://www.airliftcompany.com/shop/60796/
C-pillar flat wall
Started getting the box together a bit more today, were going to do 13 cubes, 160 sq in of port, and tuning at 29hz. Hoping it moves some air, still got some reinforcing to, building up some 45s for the corners which will be resined in as well as the entire box for better flow and strength as well as some bracing, most likely a threaded rod.
1530508_10151925803538041_2096646710_n_z
1501834_10151925804323041_1801611715_n_z
1522187_10151925804233041_1612474151_n_z
Also got some more gear in today
1526351_10151925803648041_1883465792_n_z
The 6 8s, 4 super tweeters and a few stickers
1511037_10151925803683041_608770148_n_zp
1520606_10151925803743041_2014626846_n_z
1013288_10151925803798041_895926592_n_zp
1557697_10151925804033041_1377090771_n_z
Thats about it for today, will have another update shortly
C-pillar flat wall
  • Who's Online   0 Members, 0 Anonymous, 1720 Guests (See full list)
