Justjoshiny Posted September 22, 2013 Author Report Posted September 22, 2013 first before you buy any subs tho. id make sure that box is made to fit most of the 12's, im sure it is but you never know. how much room behind your seats do you have to work with? rough estimate on dimensions? Its for under the backseat of my ext cab truck. Id say 10" ish between the floor and my seat, and 16" between the back of the cab and where I would like the box to end. Sorry I don't know the exact dimensions
Alexander Henry Freeman Posted September 22, 2013 Report Posted September 22, 2013 Hello newbie here was wondering if you could help me...i have a 98 expedition and 2 l715's i wanna build a ported box for them with the speakers facing up and the ports facing up....i dont want stuff getting sucked into the port....is it better 2 build 2 boxes or just 1 because i do not want them to share the same air space as far as dimensions...24-26 inches deep 40-48 in wide and 18 to 23 inches high. i would like to have the maximum airspce closest to 12 cu ft if possible. i would like to tune it to 35hz and will brace it with 2x4's unless you reccomend wooden dowels or the corner braces.if there is anything eles you need pleas let me know. any help is greatly appreciated as i am trying to avoid buyin the commercial box of of ebay i would probably make your own post lol. that way yours and the other guys questions and answers will not get mixed up thanks good idea....i just did
inferno1985 Posted September 22, 2013 Report Posted September 22, 2013 first before you buy any subs tho. id make sure that box is made to fit most of the 12's, im sure it is but you never know. how much room behind your seats do you have to work with? rough estimate on dimensions? Its for under the backseat of my ext cab truck. Id say 10" ish between the floor and my seat, and 16" between the back of the cab and where I would like the box to end. Sorry I don't know the exact dimensions this would make a nice little setup if they fit in the box, which they probably would as they are shallow mount and just a little over your budget http://www.sonicelectronix.com/item_39265_MB-Quart-RLP-304-Subwoofer-Pair-Combo.html shallow mount http://www.sonicelectronix.com/item_68066_RE-Audio-DTX-2000.1.html
Justjoshiny Posted September 22, 2013 Author Report Posted September 22, 2013 first before you buy any subs tho. id make sure that box is made to fit most of the 12's, im sure it is but you never know. how much room behind your seats do you have to work with? rough estimate on dimensions? Its for under the backseat of my ext cab truck. Id say 10" ish between the floor and my seat, and 16" between the back of the cab and where I would like the box to end. Sorry I don't know the exact dimensions this would make a nice little setup if they fit in the box, which they probably would as they are shallow mount and just a little over your budget http://www.sonicelectronix.com/item_39265_MB-Quart-RLP-304-Subwoofer-Pair-Combo.html shallow mount http://www.sonicelectronix.com/item_68066_RE-Audio-DTX-2000.1.html The box has room for about 7inch mounting depth so are shallow mount subs really needed? what does anybody think about these? http://www.sonicelectronix.com/item_42404_NVX-NSW124.html
