Hi guys I am new to this and the set up I am doing is
1979 Monte Carlo I am going for BIGGEST in trunk system!!!!!
I got pioneer unit with JL 300/4 for mids and highs and I got 2x1501D MTX amp's going to 2x18 BTL's fully loaded
got 10 cubes of box space before ports and displacement of speakers so YES its really tight got 4x8.5x17 port on each side fireing into the cab through the rear deck sub's fire up into the trunk lid and its 2 inches away on top and like 4 inches on the buttom angaled. NOW the problem is this 3 amps totall 1 JL and 2 MTX if I only run JL to the stereo plug in my RCA's no noise as soon I plug any of the 2 MTX amp's into the mix and the car is on very lound engine noise and the vine if I gass it NOW i can work with my JL and almost loose the noise but will loose a lot of volume oh and I am running 2 battary's one stock and one optima yellow top plus I got a cap right next to the amp's my ground is going all the way to the battary i try different ground still same thing also try different RCA's same tryed different ground for unit no luck PLEASE HELLLLLLLP!!!!!!!
possible internal ground problem on mtx amp...try to ground the outer part of the rca connection on the amp to the chassis and see if the noise goes away.
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
"try to ground the outer part of the rca connection on the amp to the chassis" What do you mean? can you please try to explain a little more
Thank you
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
