MARKMC@GMAIL Posted September 24, 2013 Author Report Share Posted September 24, 2013 Wire each sub in series like this and then hook each sub to the amp, and you will end up with a final impedance of 2ohms. that's how they are wired right now. but should I put them to same terminal bridged cause this amp has 2 separate terminals even though its mono block. Link to comment Share on other sites More sharing options...
walwalka Posted September 24, 2013 Report Share Posted September 24, 2013 All of those terminals on the amp are the same terminal, so if you hook one speaker to one set and the other to the other set. It's the same as hooking up the speakers together and running one set of leads to the amp. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin Link to comment Share on other sites More sharing options...
MARKMC@GMAIL Posted September 24, 2013 Author Report Share Posted September 24, 2013 All of those terminals on the amp are the same terminal, so if you hook one speaker to one set and the other to the other set. It's the same as hooking up the speakers together and running one set of leads to the amp. ok thanks cause it kind of confused me when I saw that. the diagram kicker8940 posted is how each sub is ran but not ran together cause I didn't have a drill at the time for my box. Link to comment Share on other sites More sharing options...
Guest Posted September 24, 2013 Report Share Posted September 24, 2013 you can either wire them like this, to one set of terminals, or each one like this, one sub on each set of terminals. same thing. all on you on how much wire you wanna use. Link to comment Share on other sites More sharing options...
kicker8940 Posted September 24, 2013 Report Share Posted September 24, 2013 See if this helps. If it was me i would run wires to each set of terminals,it's easier than trying to stuff two wires into one hole. I've tried that before especially if your using 12ga or bigger speaker wire Link to comment Share on other sites More sharing options...
jarrius Posted September 24, 2013 Report Share Posted September 24, 2013 Just because the amp had 2 sets of terminals does not mean you can bridge it. It is just there for a easer way of wiring. Both sets of terminals for that amp all supply the same power no matter what you do. There is no such thing as bridging a mono block amp 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole Link to comment Share on other sites More sharing options...
MARKMC@GMAIL Posted September 24, 2013 Author Report Share Posted September 24, 2013 See if this helps. If it was me i would run wires to each set of terminals,it's easier than trying to stuff two wires into one hole. I've tried that before especially if your using 12ga or bigger speaker wire this is actually how I have it right now. Link to comment Share on other sites More sharing options...
MARKMC@GMAIL Posted September 24, 2013 Author Report Share Posted September 24, 2013 Just because the amp had 2 sets of terminals does not mean you can bridge it. It is just there for a easer way of wiring. Both sets of terminals for that amp all supply the same power no matter what you do. There is no such thing as bridging a mono block amp that's what I thought the two terminals just threw me off Link to comment Share on other sites More sharing options...
MARKMC@GMAIL Posted September 25, 2013 Author Report Share Posted September 25, 2013 See if this helps. If it was me i would run wires to each set of terminals,it's easier than trying to stuff two wires into one hole. I've tried that before especially if your using 12ga or bigger speaker wire It's just my subs don't seem to be hitting like they should off this amp. I've seen same set up with more results but idk how they had it wired didn't look Link to comment Share on other sites More sharing options...
MARKMC@GMAIL Posted September 25, 2013 Author Report Share Posted September 25, 2013 you can either wire them like this, to one set of terminals, or each one like this, one sub on each set of terminals. same thing. all on you on how much wire you wanna use. Wouldn't the second diagram over all be a 2ohm load with both subs ran to separate terminal since they will be 4ohm each Link to comment Share on other sites More sharing options...
