Ground Zero GZNA 1.2500DXII
Bass_Maniak
all of the GZ amps are tested at 14.4V some of the biggest series like the plutonium series are tested at 13,8V
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Someone from Ground Zero was at the finals here in Alabama. They approached me and my teammate about running their amps. They have some big ones, but I do not like how they rate a lot of their amps on the website. That amp is rated as a 6000 watt max amp. This may be a problem for next years rules in DbDrag.
Bass_Maniak, you said at the top 2500 watts @ 12 volts but the manual says CEA certified 2300 watts @ 14.4 1%THD
Can you give some more detail about where your numbers are from? If you clamped it yourself, possibly a video?
Here measurement amplifier with him, we measured and GZNA 1.2500DXII.
Ground Zero GZNA 1.2500DXII showed slightly better results than Dragster daf 3001, only wish then got the battery in camera.
Measuring Ground Zero GZNA 1.2500DXII
application manufacturer
2300 watts RMS # 1 onm at 14.4 volts
1500 watts RMS # 2 onm at 14.4 volts
that I intend to:
1) supply two stinger sp 2250
51 volts
50 amp
12 drawdown
2550 watts of power was
measured with increasing voltage
powered two Stinger 2250 and 2 volts bank havker
64 volts
61 amp
13.3 volts drawdown
3904 watts of power was
Measuring DRAGSTER DAF 3001
4000 watts RMS # 1 ohm at 16 volts
2500 watts RMS # 1 onm at 14.4 volts
1300 watts RMS # 2 onm at 14.4 volts
that I intend to:
49 volts
50 amp
12.1 drawdown
2450 watts of power was
64 volts
60 amp
13.3 volts drawdown
3840 watts of power was
here is a video
Seem like bunch of bs... their large amps looks like most 2500s on market today
do not understand you?
its like you did that number with the GZNA 2500 amp..but on the other post you show how much the Dragster power was numbered....kinda not believable....(spelling?)
also you claim that the -gz 2500 did almost 4000 of rms power at 0,5(which is kinda false---does around 3240 at max with a mechman 240 HO and 2 D3100 in the back at 13,8volts )
the second of all....all of the amp in exception of some of em like DD/ AQ and some of the others are tested i belive at 11,9-12,4volts if i am correct
so unless those amps are tested at 11,9 those numbers are verry likely incorrect...as your statement is
the dragster 3001 was also tested and is not stable at 0,5--it goes into protect after a couple of secconds of playing
been there tried those amps...
the only amps that are favorite by Ground zero are the plutonium series amps
who not clear in the video!? everything is clearly visible! can daf 3001 and 0.5 ohm not stable but stable GZNA 1.2500DXII and 0.25 ohms for everyday listening to music! This is a vindicated and not just once! especially with the one we had GZNA 1.2500DXII in a sedan on the music 148 on 25Hz, and with the two amplifiers GZNA 1.2500DXII in the system with 4pcs 15 subwoofers we shot 154 at 30Hz. so that we know for ourselves that the amplifier GZNA 1.2500DXII proved to be excellent! and is a very reliable, stable low resistivity and a powerful amplifier. that tested more than once! And by the way dd M3a weaker than GZNA 1.2500DXII on a single system was a test, and M3a lost GZNA 1.2500DXII 1.5dB
actually IF you see...you DECLARED THAT gzna 2500AMP TAKES THAT POWER AT 1OHM...THEN CHAANGED AT 0.5, AND NOW AT 0.25
i call bullshit
that amp i not stable at 0,25 as i know because i used to have that F amp...0,5 is the lower you could go...with a proper amount of electrical supply
oh just for shit and giggles...we tested in a audio shop on a show car...the M3a...at 13,9(with drop voltage) it was tested 3704watts of power
im not getting argues about which one is better, because then it would become a VS thread..
if you are a GZ nuthogger then so be it...
the seccond of all...you tested at what?
clamping and proper dyno testing are 2 different things...so unless it was on a dyno...dont belive that crap
also the thing is....when driving and bumping at 3/4 of volume...you will never get the rated 14,4volts.....which the GZ and Dragster amps are tested---
except if you have A High Output alternator and a battery bank
  • Who's Online   0 Members, 0 Anonymous, 738 Guests (See full list)
