SoundQubed ohm ratings
axevon
I just got a SoundQubed SDC 2.5 12" (dual 4 ohm) in the mail today and promptly took the Multimeter to the direct leads to test the sub.
Each coil reads 5.9 ohms and I'm not sure if it is close enough to 4.
I realize that coils rarely every read exactly 4 and they often read less than their "ohm rating".
So how much is too much? I tested both at the end of the direct leads and where the lead is in the spider. The multimeter is some cheap POS from Harbor Freight if that has any effect.
Am I doing anything wrong and/or is the coil resistance too high?
Dorm room setup:
SQ SDC2.5 12" @ 8 ohms
Klipsch 300 watt home theater sub amp
Marantz 1030 amplifier
Future car build:
Audio Technix 1200.1d
Fi SSD 12 w/ cooling and flatwind coil
6th order dual reflex enclosure
Thay sounds fine its most likely resistance in the leads of the dmm put the positive and negative leads on the dmm together and see what it reads thats the resistance then minus that from the 5.9 to get your coil reading
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Thanks man, the DMM resistance is 1.7 ohm so I should be fine.
Thanks for the input! I feel a little noobish for not thinking of that but we all learn new things haha
Dorm room setup:
Future car build:
No problem! I did the same thing i have the same harbor freight dmm and was thinking wtf when i checked my coils glad i could help!
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
Your meter may not be accurate. Buy a Fluke meter.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • Who's Online   0 Members, 0 Anonymous, 440 Guests (See full list)
