Hey guys, im new to this forum but ive been into car audio for the last 6 years or so. I want to post and share the progress of my newest and biggest build yet......
Feel free to leave comments and/or suggestions. im open to discuss and answer any questions anyone may have
If youd like you can follow me on instagram and see some videos soon. user name: rgut0112
I bolted 2x4s to the factory seat bolts to screw down the false floor and also 3 big bolts in the rear where the factory strap points are. (And some temporary music while i do my build)IMG_0038.jpgIMG_0041.jpg
Walls are up
Baffle cut out
All walls and "ceiling" done along with steel bracing in the sealed section
Everything resined and test fitting the baffle before i did the steel bracing
port somewhat finished
test fitting the port and as you can see i did 45s, 3/4" steel rod through the sealed section, and sanded, painted, and some more sanding
Loading wall in and test fitting port again
some wiring waiting to be done and temporary amp to test it all out before i decide what type of power im running
sorry for the double post- it said there was a network problem with the server. This thread can be deleted.
