sprkn_ranger Posted October 10, 2013 Report Share Posted October 10, 2013 (edited) Well there you have it op, he will take care of all of your reconing needs lol. I'm done here. Edit- And by the way, the couple hundred watts (if that) extra he will see by running at 1ohm isn't going to make that big of a difference to the ear. Edited October 10, 2013 by sprkn_ranger Quote Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
STEALTH808 Posted October 10, 2013 Report Share Posted October 10, 2013 Well there you have it op, he will take care of all of your reconing needs lol. I'm done here. Edit- And by the way, the couple hundred watts (if that) extra he will see by running at 1ohm isn't going to make that big of a difference to the ear. you are right, i wonder why all these dumbasses choose to run their amps at 1 ohm, when 2 ohm is safer and sounds the same Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
sprkn_ranger Posted October 10, 2013 Report Share Posted October 10, 2013 (edited) The difference between 1ohm and 2ohms on his amp is 250w...hardly going to hear a difference. You are right...he will most likely be fine running at 1ohm, the SA subs are beasts and have been proven to take quite a bit of abuse...BUT my whole argument this whole time is that we don't know if the op is capable of overpowering a sub. It doesn't take much to burn up a coil if you don't know how it happens or what you are doing, and the whole reason he was asking if it would be a good match was cause a guy is selling one for $150 which is a good deal, but it's a d4, so 2ohm is the lowest he can wire and that amp is rated at 150w more @2ohms then the SA's are rated at. Edited October 10, 2013 by sprkn_ranger 1 Quote Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
STEALTH808 Posted October 10, 2013 Report Share Posted October 10, 2013 it is actually pretty damn hard to burn up an Sa coil under 1000 watts or so. I've tried. Im sure others have as well. Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
LoudBimmer Posted October 10, 2013 Report Share Posted October 10, 2013 I ran 2 SA-10's on SAZ2500 without any problem. 1000watts for SA is nothing really. Considering that the box is right and amp is set right. Also the amp you got will not really put out 1000wrms, at best you'll se 700-800wrms. 1 Quote Link to comment Share on other sites More sharing options...
STEALTH808 Posted October 10, 2013 Report Share Posted October 10, 2013 (edited) I ran 2 SA-10's on SAZ2500 without any problem. 1000watts for SA is nothing really. Considering that the box is right and amp is set right. Also the amp you got will not really put out 1000wrms, at best you'll se 700-800wrms. thank you for your input, seeing that you are coming from first hand experience. I just want the OP to be loud. Edited October 10, 2013 by STEALTH808 Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
sprkn_ranger Posted October 10, 2013 Report Share Posted October 10, 2013 1000watts for SA is nothing really. Considering that the box is right and amp is set right. This is exactly my point...the sub can handle it if the owner knows how to set it up right. We don't know his capabilities so we shouldn't assume he knows how. Quote Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
STEALTH808 Posted October 10, 2013 Report Share Posted October 10, 2013 1000watts for SA is nothing really. Considering that the box is right and amp is set right. This is exactly my point...the sub can handle it if the owner knows how to set it up right. We don't know his capabilities so we shouldn't assume he knows how. play your sub, learn your sub, listen to your sub. any noob can do that. Im done here, seeing as this guy NEEDS to be right. Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
Jessica Posted October 10, 2013 Report Share Posted October 10, 2013 OP, all the arguments aside, if you can get a BNIB sa-12 for $150 grab it. i'm sure you will be very happy with the 750 watts and since i doubt you have any electrical upgrades then running that mbquart at 2ohm would be better for the amp too since you wont have as much voltage drop. Plus, you can grab a second sa-12 later that is d4 and then wire down to 1ohm once you have your electrical in order and you will be all set. 1 Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
LoudBimmer Posted October 10, 2013 Report Share Posted October 10, 2013 My SA's went through hell and back. Clipping, overpowering, box too small, box too big. SA's can handle their shit. My next plan is SAZ4500 or DD M4 .......as soon as I get the electrical shit to work. 1 Quote Link to comment Share on other sites More sharing options...
