I know im going to get yelled at but since im in the process of a budget build wire expense has been a big research topic of mine lately you may wont to consider looking at Cadence 0 ofc at audiosaving.com its better wire than people think and another member of this site did a very in-depth comparison on about 15 different wire manufacturers and Cadence was in the top two. weldingsupply.com is also another place to check out good wire, good price just not as flexible. Just my opinion
http://www.amazon.com/KnuKonceptz-Kolossus-Kandy-Kable-Green/dp/B00DFSVB6Q/ref=sr_1_1?ie=UTF8&qid=1381868952&sr=8-1&keywords=kandy+ofc+wire
This is what im looking into getting. What do yall think
94 Ranger Std. Cab Bagged and Bodied
Audio under construction:
Center Console Ported Wall
4x SA-8 D2
Soundqubed 2200d.1 @ 1Ohm
Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721
2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro
4x Fosgate Punch 300.1
Big 3 Upgrade Kandywirez
XS D3400
09 Lancer Turbo
1- 12" DD 512B
SoundStream Rub1000.1 (turned way way down)
Avix-930bt
Just trying to find something that will last. I will be running 2 XS d3400 Battries with 2 viair compressors for my bag system and then ill be running 2 Rockford Fosgate 400-1's for my mids in the doors and then a Q1-1200D Audio Qubed Amp for my sub. Looking into either getting a second alternator or a single 200+ amp. Sound alright?
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
Now with the 2 battries can i just run a 0ga jumper from one to the other or run 2 seprate leads from ATL?
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
You can jump them or just run seperate leads, that's up to you.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
What would be better? I dont want a half ass set up
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
you can use jumpers but you might want to consider running two runs of 0 one will do but two would be more efficient. two runs to batteries and jumpers across the batteries will keep everything charged. wire the batteries in series. the 12volt.com is a very useful website
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
