Skar Audio T-Series Amp Clamp Test Results
The brand new T-Series Series amplifiers are a brand new product line from Skar Audio, and with that being said we wanted to get some clamp testing done to go alongside our SMD AD-1 Amp Dyno results with these amplifiers, so you have a variety of tests to see their power output capabilities...
Testing conditions/setup was identical on both amps, allowing for an easy comparison between the line. We are very happy with the results, and this will give you a baseline reference point when browsing and choosing from the compact amplifiers on the market.
Only the Monoblock Amps in the T-Series line have been tested so far, which is the reason for the exclusion of the 2 new 5-Channel models. We will test and post those results shortly!
Head Unit Volume : 60/62
Head Unit Sub Level : 6/6
Test Frequency : 50 Hz
Test Load : (1) ZVX-12 D2 resting @ 0.8 Ohm
Test Electrical : (4) Non-Charging Shuriken SK-BT75 12v Batteries
Amp Gain Set Level : 1/2
Skar Audio T-1400.1D
POWER OUTPUT : 1325 Watts (calculated)
AMP CURRENT : 27.6 A (measured)
AMP VOLTAGE : 48.0 V (measured)
ACTUAL IMPEDANCE : 1.74 ohms (calculated)
SUPPLY VOLTAGE : 12.86 V
Skar Audio T-2000.1D
POWER OUTPUT : 2365 Watts (calculated)
AMP CURRENT : 37.6 A (measured)
AMP VOLTAGE : 62.9 V (measured)
ACTUAL IMPEDANCE : 1.67 ohms (calculated)
SUPPLY VOLTAGE : 12.48 V
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
Looks Good! Keep up the good work!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
