Enclosure Build: 12" kerfed, bedlined, birch :)
Question for you sir, what spacing between cuts and how much wood you leave for kerf?
For this I just went with 3/8" spacing between cuts just to be safe but you can map out your kerf on cad/sketchup etc (or just use math, circumference of circles etc) to see exactly how many cuts you need to make by taking the difference between circumferences of the inner circle of the bend and the outter circle and deviding that by your blade wdith to see how many cuts it will be and then do the math for spacing for the width of the bend.
Great box man...do you ship/build boxes???
Yezzir. I design and build for WooferWarehouse.com, ordering and pricing info is on the site :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
