ChevyBoy95 Posted October 29, 2013 Report Posted October 29, 2013 Welcome to my UBL, wanted to make this to help clean up my build log all around.comments can be made here:http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/this being a while back in may. This is the construction of my console. Used some wood filler for the speaker ring to help it meld into the wood and give a nice look to it. Going to house a ONX 4.125 and my relay set up from Tony Candela(later on).you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 piecing together the console with some titebond II and ratchet bars. looks much better when the paint starts getting sprayed on. then the ONX4.125 and my relay. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 trying out some new pyle mids, hard to pass them up at 20 bucks a pop. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 got my TPI 440 Scope Plus adding 2x4's to the back wall to reinforce it, was loosing a ton of low end output with the extreme flexing. cut a hole to run my wires from the toolbox down under the truck near the frame. started on the platform for the truck. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 came out pretty well in my opinion, could have been better, but it all gets covered anyway. started on my kick panels dont mind the trash, was consolidating all my audio boxes, card board cut outs, school papers, etc to trash. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 initial resin and grinding on the driver side kick backshot of the driver side kick after some grinding. self explanatory a test fit of the mid (LIKE A GLOVE!!) you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 new amp for the console, taking the onx4.125 out another look at the console with amp inside. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 got me some more wire. and started on my 3 15's box for 3 AQ HDC3 15's you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted October 29, 2013 Author Report Posted October 29, 2013 lastly for now... some deadener on the roof. you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/ Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
