banginhummer Posted November 1, 2013 Report Posted November 1, 2013 Ok I designed the box, but need help with the port, which will have only 1 common wall. here's some specs on it. can anyone design the port and calculate the length for me also, this is a two part box, another box at bottom, will all be connected and siliconed together would like it to be tuned from 32-35hz subs are 4-15 massive hippo here's what i have some specs bottom box, still working on top piece. Lincoln Towncar bottom E n c l o s u r e S p e c i f i c a t i o n s : F b = 3 5 H z V b = 8 . 6 f t ^ 3 Bottom Piece E x t e r n a l H e i g h t = 7.75 and 9.75 i n E x t e r n a l W i d t h = 40 i n E x t e r n a l D e p t h = 27 i n C u t S h e e t L i s t : * A l l D i m e n s i o n s i n I n c h e s . * W o o d T h i c k n e s s i s 3 / 4 f o r a l l P a r t s . E x t e r n a l E n c l o s u r e P a r t s : 2 x T o p & B o t t o m (x2) ( 3 p a r t s ) = 4 0 x 2 7 L e f t & R i g h t S i d e s = 25 1/2 x 7 rising to 9 (4 1/2 angle) F r o n t 40 x 7 B a c k = 40 x 9 yes bottom has wedge, trunk dips a bit would like the port on top like this *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO)
