Help with impedance level on amp
Barcanescu Constantin
Are u sure it's 47k and 0.6k? That amp has a dial for the Variable input level: 200mV - 9V, which is simply to set the input voltage to match the headunit and rcas. There is also a low pass filter 35- 250 hz (to set the crossover point for the sub(s)
Ipad mini as main source unit, w/ Kenwood KDC-U7056BT,Digital Designs CS6.5 2 way components, Alpine PDX-F4 4 channel & PDX-M6 mono, x1 Jbl P1224 12", single ported box @ 34hz, front doors + trunk sound deadened w/ dynamat xtreme,all knukonceptz wiring/fusing.
*In progress - Audison bit ten d dsp, fully optical.
oh thats just for balanced input. if you're using regular rca's then dont worry about it.
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
