Thanks for the tip, where on ebay can i findt that audioshop... cant seem to find it?
Anyone have a link?
http://stores.ebay.com/High-Desert-Audio-Store
I just looked and they don't have any posted. Email Chris at [email protected]
I am sure he has some.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Thanks!
Well its decided!
Its going to be 2 15" Woofers. In a huge ass box!
BUT!!
Amp is not yet decided! As i need to get the items sent to NORWAY.
So i have to look for either 2 15" T1`s And a T10001 maby? :D Since ive heard you cant go wrong with RF:D
Wait a minute now, While i love my T1 15s I truely think they are over priced. Just keep your opitions open for subs.
You could get FI BL's for the same price as the RF 15s. The kicker CVR's are cheaper but i don't think the quaility is as good as RF or FI. Might look at getting some better kickers so they last longer. If you can be responsible and not pound the CVRs all the time other then the 30 seconds for bassracing, then they should last you awhile.
I do box designs.
Hmm, that sounds good!
Can get a good deal on 4 12" CVR`s for measly 196$ but i have to add 284$ in shipping!
But that is WAY CHEAPER then what i can get them from i Norway!
I could buy these from INDO AUDIO off e-bay!
So 4-12" should be more cone then 2 15"`s
Hertz - Pioneer - Zealum
Yes four 12s are 452 square inches vs. two 15s with 353 square inches.
You might want to step up to a 2000 watt amp if you get four 12s.
The CVRs are 500 watt rms each, so thats a total of 2000 watt rms.
Your amp opitions will change when you get four 12s.
I do box designs.
yeah, im able to get 3000wRms fairly cheap. So that is no problem!
If they are dual 2`s i can put them in 1 ohm. And if its dual 4 ohm i can get them in 2 ohm correct?
Because if i can get all of them to 2ohm. Even wire 2 and 2 subs to 2 ohms each whould be gret!
Yes, whatever ohm load the amp peaks at depends on what subs to get.
Amp peaks at 4 ohms you want 4 dual 2 subs
Amp peaks at 2 ohms you want 4 dual 4 subs
Amp peaks at 1 ohm you want 4 dual 2 subs
Amp peaks at .5 ohm you want 4 dual 4 subs
I do box designs.
Peaches!
Then ill go for dual 4 ohm!
what amp are you getting?
What are the ratings at what ohms?
Edited by banginAltima
I do box designs.
  • Who's Online   2 Members, 0 Anonymous, 1645 Guests (See full list)
