banginhummer Posted November 6, 2013 Report Posted November 6, 2013 If anyone can assist, that'll be greatly appreciated. *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO)
mrd6 Posted November 6, 2013 Report Posted November 6, 2013 Can you explain what you mean exactly? My response below is to what i think you are asking.... Just draw a circle on a plane and then either simply select and delete the insides of the circle or if you have a 3d surface, draw your circle and then extrude it to the depth if your 3d surface and the insides will delete automatically leaving you with a nice cutout My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Jessica Posted November 6, 2013 Report Posted November 6, 2013 he means use push/pull tool to push the shape and the texture of the shape will change. let go of the mouse button and it should disappear. It takes a few tries to get it right. But push pull is the only easy way i know with a 3d surface. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
banginhummer Posted November 6, 2013 Author Report Posted November 6, 2013 Ok, i tried that once before, and nothing happened. I will try it again. I have 20 holes, was looking for an easier way. *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO)
mrd6 Posted November 6, 2013 Report Posted November 6, 2013 Push pull tool is what I meant by extrude. You can also either shift or control click(can't remember which) multiple pieces and copy paste. So you could copy paste complete cutouts if you wanted My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
banginhummer Posted November 8, 2013 Author Report Posted November 8, 2013 Thanks man. I got it *Hummer H3* HeadUnit Pioneer AVH-X4600BT Mids and Highs 8-CT Sounds Pro 8" 8ohm 4-CT Sounds Pro Tweeters Amplifiers 1-CT Sounds 125.4 1-CT Sounds 60.4 1-CT Sounds 7000.1 Electrical 3-Runs of 1/0 CT Sounds 8-XS Power D3100 3-Iraggi 300 amp Alternators Subwoofers 4-SQ Hdc3 15" Subwoofers (Soon to be 4 15" Ct Sounds EXO)
