GM (buick) 3.8L 3800 series gurus out there?
Anyone familiar with this series engine very well?
I'm looking at one where the car drives fine but is making a noise under throttle that as the RPM's increase so does the whine. I almost sounds like an old belt that needs to be replaced but it's not. As you give it throttle the noise gets higher pitched in sound and appears to be coming from where the aly is but my hearing is so bad I cant tell.
Any input? I've heard the 3.8L is almost indestructible.
Rolex you sicken me.
Just let me finish my pie
~ Juice
Is it supercharged? Take off the accessory belts and check all the pulleys: idler, tensioner, power steering, alternator, spin them to see if they make scraping noises or check for wobble. If it makes the noise only when your ac is on it could be your ac condenser.
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Mids/Highs: Alpine SPR-50c 5.25" components
Mids rear: Alpine SPR-69 6x9
Mids amp: Alpine MRX-F65
Power/Ground: Massive Audio 4 AWG
Signal Cable: Massive Audio 14 Gauge
RCA's: Monster cable
Subs: 2 Rockford Fosgate HX2 12's
Sub amp: Crescendo BC2000D
Custom box - Herculiner with Silver port
Big 3 and power/ground - Sky High Car Audio 1/0 OFC
Coming soon:
H.O Alternator Singer or Mechman
not SC.
Turned ac off and still there. This is on a car i'm looking to buy, just want to make sure its nothing crazy. If its a belt or puller or arm no biggie, I can fix. but I don't want to go into a motor! This is the 1st 3.8L I've ever considered buying.
thanks
~ Juice
if its not knocking and just whine it should be an easy fix
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Coming soon:
try reving the motor by hand at the throttle body and carefully use along screwdriver, one end on the accessory, alt, p/s pump,... and the handle end ON your ear. you will here the same sound through the screwdriver.
03 s-10 owned since 35k now 150k
alpine type-s 6.5 comp
alpine type-e 10 ported fiberglass
jl 300/4 (dead)
jl500/1 (dead)
mine whines a bit. non s/c.
i've heard some 3800's that whine because of the power steering pump.
but yeah the motors are crazy strong. as long as the intake manifold gaskets have been replaced or are in good shape and not leaking coolant.
the transmissions (4t65 and such) on the other hand are a joke lol.
4L60E trans
rwd car? i take it you have that firebird that you linked to earlier in the picture?
picking it up tomorrow. Hoping to get a car fax too. The pic above isn't it. I'll post the car a little later.
The Cavi was killed by a drunk driver 3 weeks ago
~ Juice
