Atomic apocalypse 15 box help
pimpnFosgates
My max dimensions are 34wx28dx17t
I want just a straight numbers box. It's on a sound stream 2600.1 in a 98 subaru legacy outback(wagon)
I built a great low end box that plays to 15 hz but now I want a numbers box and need to know where I should tune it, aeros or slot ports? I've never went for just numbers so I don't know what to do
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Come on guys, basically I need to know around what I should tune to and if I should try aeros
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Find the vehicle's resonant frequency where you have the most cabin gain, then you will want to tune not necessarily at that frequency, but so that you peak at that frequency. Normally you will need to tune a couple Hz lower to do this. And it doesn't matter if you use aeros or a slot port, a port is a port as long as you have the necessary port area. It would be easiest to plot this in WinISD to try to mess around with the volume of the box vs power and see how large you can get the peak when you look at SPL.
Chevrolet Tahoe
Crescendo PWX6 (2) and FT1 (2)
Fi Audio SP4 15" (1), AQ3500D.1 (1)
Enclosure: 4th Order (Ported) 4.5cu ft @26Hz
Mechman Elite 370A & Kinetik HC2000
Sky High 2/0 Wire
Future Plans: (2) 18" @25Hz
  • Who's Online   0 Members, 0 Anonymous, 5496 Guests (See full list)
