Renault Megane 4 Fi sp4 18s Walled 12k -- 510 pics
I went to Trax yesterday and being a French car it always breaks down on the way to shows so on way there got very bad wheel wobble stopped twice to check everything seems done up tight.
Took wheel off once there and noticed one of the studs on my adapters had snapped off. The car also has a leaky exhaust manifold which causes my turbo not to boost properly and also leaks the fumes into the car so i have to drive with windows open.
The problems didnt stop when it came to the audio side either. On the drive there i noticed my voltage was all over the place the external reg is set at 14.7v cold and when hot it drops to 14.4v but driving there it was sitting on 13.2v idle going up to 13.7v driving thats with music on minimum volume and if i turned headunit and amps off it went upto 14v.
Still got the car tested anyway and even revving and holding at 2k rpm the car stalled on every tone even saw 9v at times and my dash started flickering and displaying different letters and funny symbols.
My average score was down by 0.2db on my previous scores which also was done with poor voltage.
I think the problem has to be down to earths so will to have to go through them all checking connections and adding more if i can. Maybe add a front battery see if that helps.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 Renault 210a Alternator
1 Hertz 15k Spl Monster
2 RF T600-4
16 RF T162s 6.5" Mids
16 RF T1T 1.1" Tweeters
4 FI SP4 18" D2 subs
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Build Log: http://www.stevemeadedesigns.com/board/topic/178428-renault-megane-4-fi-sp4-18s-walled-12k-457-pics-termlab-scores/
still some good numbers!
2002 chevy avalanche
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
Second set of T2652-s
D3100's
deadner
  • 1 month later...
Havnt updated this in a while but im getting rid of the Megane so started stripping the audio out and boxing it back up.
Still got big amp and batteries to take out tomorrow then try and get cables out somehow.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Nothing audio related, the car will be sold for bits and im looking for new car to put audio in. The Megane didnt get near enough to 160 as i was hoping so need more space and a crazy box design maybe a 6th or 4th order.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
