(2) SA 15s
dfoland93
So im going for (2) SA 15s aero ported on a AQ 2200 @ 1ohm. Im not too sure but i thought they liked bix boxes and more port? Going in a 02 Rodeo
Box:
3/4 baffle
W: 35
D: 24
H: 22.75
Port:
2 6" Aero Ports
Sraight Length: 16.5
Flare Length: 17.5
8.1cubes @ 30hz
I was contemplating having someone build a box for me but im assuming itll be in the $150 range, which is out of my price range. Criticism welcome.
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
I would use more port area, and $150 to have a box built isn't bad at all.
Builds:
Max Dims: 41W x 22H x 25D
I could go more H but it would look weird i think over the head rests in the back
No Engine
If i were to do a 10" i wouldnt have the right amount of space between the flare and back side of the box, same with 2 8", 3 6"
I could do 4 4" though
No Engine
Four 4" ports would be even less port area than two 6" ports. I'd do a slot port if you can. Then you can make it whatever size you want.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 5496 Guests (See full list)
