Prefab sub wiring
kadrek
I found these prefab subs, http://www.amazon.com/Rockford-Fosgate-P1L-2X10-Pre-Loaded-Enclosure/dp/B0027GV2RA I'm wondering how they're wired up inside the box? It says it can take 300 rms, I'm assuming they're the 8 ohm versions wired in parallel correct? Like this, http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2SVC_8-ohm_mono.jpg ? Is there just one wiring terminal on the outside of the box? Would this amp be a good match with these subs as it puts out 300 rms at 4 ohms? http://www.amazon.com/Alpine-MRV-M500-Mono-subwoofer-amplifier/dp/B00BMR7UPS/ref=sr_1_1?ie=UTF8&qid=1384315346&sr=8-1&keywords=500+mono+amp
Thanks in advance
If you read the spec's, it say's two 8 ohm subs wired in parallel. To give you a 4 ohm load. That amp will work, but the pioneer gm-d 8601 would be a better option.http://www.amazon.com/Pioneer-GM-D8601-Class-Amplifier-Remote/dp/B00A02QLVA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1384316277&sr=1-1&keywords=pioneer+8601
truthsayer
The link you provided for the pre-fab loaded enclosure answers your questions about it.
P1L-2X10 Specifications Woofer Quantity: 2 Woofer Size: 10" Woofer Series: Punch P1
P1S810 Woofer Impedance: 8-Ohms
Wired in parallel internally to create a 4-Ohm amplifier load. Power Handling: 300 Watts RMS
600 Watts Max System Configuration: Vented Enclosure Material: 5/8" MDF (Medium Density Fiberboard) Speaker Connector: 16 AWG to 12 AWG Compression Terminals Dimensions: H 13.125" x W 31.125" x D 15.75"
Yes it has one set of binding posts on the side of the box.
I learned all of this in about 10 seconds.
It's ok bro, I hate it when my :google: breaks too!
P1L-2X10 SpecificationsWoofer Quantity: 2 Woofer Size: 10" Woofer Series: Punch P1
Yea, I was like ohhhhh when I was typing it out, just wanted to be sure.
I've never seen a mono amp with four places to put speaker wires. Which of the four places would I put the wires from the subwoofers in? The two to the right like in the manual? Don't you have to bridge them or something to get 500 rms @ 2 ohms?
When a mono amp has more than one speaker terminal it doesn't matter which one. Think of it as a distribution block. Just pick a set and your done.
No need to try to "bridge" anything.
Okay, thanks. Sorry, I was in a hurry.
  • Who's Online   0 Members, 0 Anonymous, 5496 Guests (See full list)
