2006 Honda Accord full active SQ build
Sound Quality car audio build for a 2006 Honda Accord sedan. The goal of the system will be a stealth build where everything in the trunk will be out of sight.
Goals of build:
-Provide Great sound quality
-stealthy trunk build and leave as much space possible for daily
use
The list of products
Pioneer DEH-80prs Headunit
Mosconi 6to8 DSP
Mosconi Gladen one 120.4 amp
Mosconi Gladen one 240.2 amp
Image Dynamics IDQ10D2 V.3 10" subwoofer
Illusion Audio Carbon C6 6.5" components
The pioneer 80prs was installed using Bestkits install in lower storage pocket. wire harness and steering wheel control for the
aftermarket head unit.
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
next moving onto the doors, removing the panels and treating sheet metal
with focal Bam xxl and blackhole tile.
Had to trim a little of the sheet metal to fit the 6.5" mids
Next adapters were made from 3/4" mdf for the front doors to mount the illusion audio c6 mids. Then adapters were sprayed with bed liner.
Then the mid was installed in the door on the adapter
same was done to the passenger side door.
SQ Build Logs
Next the tweeters were installed in factory location to have a stock appearance. The tweeter grills were removed so the oem grill over would fit nicely over them in the dash.
oem grill cover on.
SQ Build Logs
Moving on to the rear doors, they received the same treatment as the front doors.
SQ Build Logs
I ran 1/0 gauge power wire to power the system on the driver side and ran the signal wires down the passenger side.
SQ Build Logs
Moving onto the trunk, a 3/4" mdf base was mounted to the spare tire area to house the amp rack and a sealed .75 cu.ft enclosure. screw rivets were used to secure the base to the car.
SQ Build Logs
Next the trim panels are cut, routed and sanded.
SQ Build Logs
The trim ring that hide the sub woofers screw mounts in place using neo magnets.
SQ Build Logs
wire management
SQ Build Logs
