Correct me if im wrong.
DJ_Stubbs
But i have a 2 ohm SoundQubed HDC3 12"
And a Hifonics Brutus BRX1600.1d
And I was just curious, I feel like its wired wrong.
There are 2 sets of red and black wires from the sub. I wrapped them together and wrapped another wire and ran that into the amp.
Is that right?
And i was trying to figure out if i should change it to 1ohm or 2 omh.
2007 Dodge Caliber SXT 2.0L
Flowmaster Single muffler + Tip
4 SoundQubed 6x9s 3-way
PolkAudio PA660.4
2 MB Quart Tweeters
2 4" MB Quart 2-way
New 8" coming soon!
So is my sub running 2 ohms then? Should i maybe change it to 1 ohm?
But i have it wired right correct?
PolkAudio PA660.4
2 MB Quart Tweeters
2 4" MB Quart 2-way
New 8" coming soon!
D2
PolkAudio PA660.4
2 MB Quart Tweeters
2 4" MB Quart 2-way
New 8" coming soon!
Yes i have both reds twisted, and both blacks twisted, then i twisted 1 wire onto each twisted set. Into the amp. so its 2 reds to 1 red and 2 blacks into 1 black into amp.
PolkAudio PA660.4
2 MB Quart Tweeters
2 4" MB Quart 2-way
New 8" coming soon!
Like that it is wired to 1ohm I have the same sub wired the same way. Did you put electrical tape and it wire nuts on it also so they can't touch each other?
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
You got it perfect. You may consider something better and more permanent than just twisting them together. Bolt terminals on the Inside, with terminated ends.
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
